Message 1 of 8
Pairing with app
I have just got a new BT TV Pro box and it won’t pair with the app on either my iPhone or iPad
BT have told me that it cannot be done at the moment but I an wondering if anyone have a workaround for it?
7 REPLIES 7
Message 2 of 8
Re: Pairing with app
There's a known issue at the moment that you can't pair over wi-fi (it won't find the box). Connect an ethernet cable just long enough to pair with the app, and then you can disconnect it.
Message 3 of 8
Hi
Unfortunately I am using Ethernet to connect but it still doesn’t pair
Message 4 of 8
Does it fail to pair, or fail to find the box?
Message 5 of 8
It says no BT TV box found
I have given local network permission to the app
Message 6 of 8
If your phone is connected to the same network then step 1 is to reboot everything - phone, router, set top box, and any WiFi repeaters or switches.  Then try again.
If that doesn't sort it then try a maintenance mode reset of the set top box - the pairing service has been known to die, although this will be the first case I've heard of it happening on the Pro box.
Message 7 of 8
Thanks, I will try that tomorrow🤞
I will report if it works or not!
Message 8 of 8
Update to my problem
I have just tried to pair the box and without doing anything it worked with no problem!!
Thanks for your help
