Message 1 of 4
Remote code for sharp androidtv
Hi all,
Ive been investigating for the last 90 mins. Trying to pair my tv remote with my new sharp aquos androidtv. Obviously 4848 doesn’t work, tried Hisense and tons of others like 0039, 0093, 1763…. All found by doing Google searches!
any clues? My tv is a 50BL2KA
thanks
3 REPLIES 3
Message 2 of 4
Re: Remote code for sharp androidtv
Try this one
Vestel (2811)
Message 3 of 4
Lovely! That code worked, BUT, two important findings:
-it took quite a long time for the remote to find the right signal, I was pressing the on (TV) button for at least two minutes
-you must release the TV button on the remote as soon as it switches off or it will select the next code and that won’t work
Message 4 of 4
The 2811 code didn’t work for me unfortunately.
