Message 1 of 4
T4000 won't update to latest software
Hi,
I just bought an old DTR-T4000 on ebay just for watching freeview, but it is on really old software (Manufacture version: 26.40.0, Component: 3.0.47) and I can't get it to update to the latest version.
If I go to Settings/Software Update it says "You currently have the latest YouView software installed. Software up-to-date".
I think I've tried all the maintenance mode options. Internet/USB Recovery wouldn't even start. (It wouldn't start on my T2100 either, but Software Update worked on that, so I know my network connection is OK).
Any ideas?
Thanks,
Damon
3 REPLIES 3
Message 2 of 4
Re: T4000 won't update to latest software
I meant to add that I've tried different hard disks, so that isn't the problem.
Message 3 of 4
@dac
From what I remember that's the old list version before they ruined it by modernising the interface.
I suspect that all the update links have since changed so the links on your box go nowhere now so I reckon you're stuck on that version.
Some years ago I had a list of all the links used and tried blocking updates with my router but I missed blocking 1 update and then my blocking failed after that suggesting a change to the links and with the demise of Youview support there's really nobody to turn to.
Message 4 of 4
That would be a shame. I prefer most of the new interface and my other boxes use it.
I don't think they provide files for a USB update. That would be handy.
Thanks anyway.
