Message 1 of 10
TV remote code not working for Sharp TV...tried all possibilities!
Anyone able to help please?!
Tags (1)
9 REPLIES 9
Message 2 of 10
Re: TV remote code not working for Sharp TV...tried all possibilities!
Hi @wbrooke, welcome to the forum and sorry you are unable to get your BT TV remote to control your Sharp TV.
Have a look at How To Control My TV With My BT TV Remote and see if the code(s) provided work for you. If not then check the user guide for your Sharp TV as the guide often provides the code for other remotes.
cheers
John
Message 3 of 10
Thanks John,
Sadly, it seems an imppssobility. Spent hours trying and looking for a solution online but nothibg as yet.
Annoyingly, on the original TV remote, the power button is no longer working so have still kept my old Sky one purely to turn on and off. More remotes than I really want!
Message 4 of 10
Had the same problem. Found the code for Vestel (2811) worked.apparently they make Sharp televisions too.
Message 5 of 10
I was having this same problem earlier..  need to program the BT remote because the standby button on our TV is nearly kapput
Message 6 of 10
And it works 👌
Message 7 of 10
I’m having the same issue with my brand new sharp androidtv. None of the codes work! I’ve tried dozens of them… when trying 4848 is the only one that seems to pair, but my tv is not switching off. Help please!
Message 8 of 10
I’m having the same problem.
Message 9 of 10
The 2811 code didn’t work for me.
Message 10 of 10
How old is your TV? Hisense used to make Sharp TVs' until either last year or 2020, I'm not sure which
