Distinguished Guru
Distinguished Guru
Message 11 of 24
Re: Another Yahoo hack.
The only BT employees on this forum are clearly identified as moderators or specialists, and the rest are generally customers. Why is it that some people think that nobody but BT staff can possibly disagree with them?
Message 12 of 24
No, nor am I defending them. Just pointing out that you are not forced to use the mail system that BT choose to employ.
mrtilly
Message 13 of 24
thanks for the info on Bt Employees, i don't think that nobody should disagree with me. However I paying for a service with BT so why should I have to go to some were else to provide my email?.
Message 14 of 24
You don't, it's just an option if you want to because you don't have to use the BT email system.
If you are happy with what you have stick with it, if you are not happy you can of course go to another provider. Just make sure you check who provides their email service and how secure their email system is. They have virtually all been hacked or had data breaches at some point.
Grumpy2016
Message 15 of 24
I took my own advice and wrote to the top and received the following reply:
I can confirm that we are continuing to transfer our customers over from BT Yahoo Mail to the BT Mail platform.
This isn’t something that can be done overnight and will be done in batches to ensure all is done correctly.
I then checked my email account and both addresses are now on BT Mail.
Success!
Message 16 of 24
How did you check them?
Message 17 of 24
How did you check?
When you log onto your BT email via webmail what does the BT Logo show. Is there any mention of Yahoo?
Grumpy2016
Message 18 of 24
I used this shortcut to check that I was on BT Mail
http://pbtcsc.bt.motive.com/login/?workflow=EmailChecker&s_intcid=con_searchpriority_genericmail?s_i...
It worked for me
Message 19 of 24
That method is faulty and is giving false readings. You need to log onto your email via webmail and check the logo.
See link
http://bt.custhelp.com/app/answers/detail/a_id/57483/~/im-not-sure-if-ive-got-bt-mail-or-bt-yahoo!-m...
If you were migrated there is a further procedure that you would have to go through in order to complete the migration which if you have not done it means you are still on BTYahoo.
Message 20 of 24
The checker is broken and cannot be relied upon. The only sure way is to check which branding is shown in webmail. http://bt.custhelp.com/app/answers/detail/a_id/57483/c/7339/?workflow=EmailChecker
