Message 11 of 13
Re: Are there issues with webmail versions of email - gone a bit iffy
Thanks Neil,just took delivery of my Mac Desktop yesterday , have a  guide for Seniors/ Dummies on the way!!
Message 12 of 13
@Filosopher This link to the Apple Help shows you how to choose private browsing. Did you only encounter the webmail login problem on the new Mac?
Neil
Message 13 of 13
Like others I had problems on all devices yesterday but they were solved on ipad and iPhone.  The BT Email is on
my launch pad on the Mac and I need to remove it at some point.  Not urgent, I use iPhone and ipad primarily for my emails and can access them via My Bt on the desktop. Thanks for your suggestions.
