cryptogram
Message 1 of 5
How do I attach a document in BT email?
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Attachments
In webmail click the icon above the text box next to "Attach file ...". If using an email client (recommended) it will be something similar.
cryptogram
Message 3 of 5
Re: Attachments
Thanks.
BML3
Newbie
Message 4 of 5
Re: Attachments
I cannot drag or copy/paste an attachment to email. No connection appears and email goes grey. It is an NB email - can anyone help, please?
rebelkc
Message 5 of 5
Re: Attachments
I've had the same issue for a few weeks now .... cannot attach anything using Webmail ... but is fine using Windows mail
