Message 1 of 4
Auto forwarding of emails
Please can someone tell be how to set my @btinternet address to auto forward incoming emails to an  @gmail.com address?
3 REPLIES 3
Message 2 of 4
Re: Auto forwarding of emails
Hi @wrecker login to webmail, click on your email address in the top right then click settings.
On the left side of the screen, click mail, then Autoforward, tick enable autofward and put the gmail email address in the destination box and click save.
I hope that helps?
Neil
Message 3 of 4
Be aware that auto forwarding does not count as using your email account and if you don't log onto your account at least once in a 90 day period it will be suspended then deleted.
See link section 7
https://www.bt.com/products/static/terms/feb2017btmail.html
Message 4 of 4
Many thanks for the information
