Message 1 of 8
Avatar
I have this strange cartoon avatar attached to my email account which I can't get rid of! If I click on the camera on the picture it doesn't allow me to change it, and it is the account I use for work etc so quite embarrassing.
Any advice how to remove it?
7 REPLIES 7
Message 2 of 8
Re: Avatar
if you go to top of page then click your avatar then select settings then avatar then you can change it
Message 3 of 8
Re: Avatar
Thanks but that doesn't work. If I click on the avatar it takes me to an account info page and no settings option. In the other settings options there is no avatar option.
Message 4 of 8
Re: Avatar
if has to be avatar at top of page next to envelope  you should then see profile , settings etc
you obviously have to be logged in
Message 5 of 8
Re: Avatar
Nope - unfortunately nothing there. I have been through every single setting available, nothing that says avatar or even profile. If you click on settings there are no options to change this. If you click on the avatar itself it takes you to an account information screen offering ways of managing email account, changing password etc.
It is so frustrating! This is an old btinternet email address.
Message 6 of 8
Re: Avatar
sorry my fault  I misread your post and I thought it was the forum avatar you wanted to change
have you been migrated to BT Mail from BTYahoo mail?
if you log in to your email using web mail can you not make changes there
Message 7 of 8
Re: Avatar
Ah ok thanks.
No I think I am still on bt yahoo mail..  unfortunately logging in via webmail seems to brings up the same page.
Moderator
Moderator
Message 8 of 8
Re: Avatar
Hi @kiranasreen,
Thanks for posting. Can you post some screen shots of what you're seeing? Remember to edit out any personal info.
Cheers
David
