welshdragon
Message 1 of 4
BT Yahoo Mail & attachment problem
Hello All,
I have tried attaching a file to an email, ( one that I do every day ) size about 3mb, but today I have tried attaching it and whilst the indication 'Attaching File' and the square icon appear, the small rotating circle just carries on forever and no indication at the bottom of the square icon appears.
Any suggestions gratefully received.
3 REPLIES 3
Message 2 of 4
Re: BT Yahoo Mail & attachment problem
Others have reported this problem in the past and a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds resolved it.
huntwr
Message 3 of 4
Dear All, We too have experienced this problem. If it is a problem that is being experienced by a number of users then it would suggest that the root cause is not the hub but something systemic. The problem comes and goes but the solution must lie with BT rather than individual home hubs. Any ideas BT?
welshdragon
Message 4 of 4
Thanks for the replies and I have solved the problem by switching the power off to the Hub (2) and left it overnight, just attached the usual file in a reply today and all is back to normal.
I tend to agree with huntwr.
