CatWeasel
Message 1 of 8
BT Yahoo e-mail problems on an android
Hi Everyone,
I hope you can help, I recently got a "HTC One X+" android smart phone (android OS is 4.1.1) but have had huge problems receiving all my BT yahoo e-mails on the device. I primarily use 2 e-mail addresses, G-mail and BT yahoo, the G-mail works perfectly and I receive all the e-mails, the BT yahoo e-mail account however never delivers about 50% of the e-mails to the HTC phone. It is worth noting that the BT yahoo e-mail works perfectly on my PC using outlook and on my old iPhone 4, at the end of the day if I check the BT yahoo e-mails I received on outlook (or the iPhone) and compare it to the android phone I can clearly see e-mails that the android phone never received. At first I thought it was perhaps an App, so I tested some of other e-mail android apps on the phone but they all have the exact same problem. The phone settings I have tried are:
Incoming settings:
Protocol: POP
POP server: pop3.btinternet.com
Security type: None
Server port: 110
Outgoing server settings:
Login required: Check
SMTP server: mail.btinternet.com
Security type: None
Server port: 587
Incoming Settings
Protocol: IMAP
IMAP server: android.imap.mail.yahoo.com
Security type:  SSL
Port 993
Outgoing settings
SMTP server: android.smtp.mail.yahoo.com
Security type:  SSL
Port 465
Both give me the exact same problem where its hit or miss if a BT yahoo e-mail will ever be received by the HTC phone, has anyone had a similar problem or can see something wrong with the settings I am using? Smiley Sad
Message 2 of 8
Re: BT Yahoo e-mail problems on an android
The settings you need are on this page
Using e-mail on your mobile phone
You just need to drop the android bit that you added.
Also, if you are using POP3 on Outlook, make sure that you tell it to leave the messages on the server, otherwise you will not see them on your phone.
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
CatWeasel
Message 3 of 8
Hi Keith,
Many thanks for the reply I had tried without "android." (at the beginning) previously, I only added that after googling the problem where I found a forum post suggesting it, I have now set the phone back to use your recommended settings. I do use POP3 for the outlook e-mail connection setting and your comment's a good one, not something I had thought to check before you mentioned it. I have now changed the outlook account setting so that it retains all mails on the yahoo mail server for a set period of time before deleting them, on the off chance the problem was due to outlook grabbing the mail first and perhaps removing it from the server before the HTC phone had a chance to sync to receive it.
I'll monitor it for the next couple of days and will update this thread once I have had a chance to see if it makes any difference, thanks again.
Message 4 of 8
Try using the BT Yahoo App from the Google playstore. It's free and is easy to set up. I have used it for a few months now without problems. Having said that there is a slight glitch since the last update where it doesn't always push the email but this is a known fault that will hopefully be fixed shortly. It is not a pop3 email client, it works directly with your BT account.
You could also try the following settings. (you may need to change the server name to mail.yahoo.com rather than btinternet.com)
Also noticed that you have put POP server: pop3.btinternet.com. remove the pop3 part and make it mail.btinternet.com
INCOMING
Username: Your email address
Password: your normal email password
POP3 Server: mail.btinternet.com
security: None
Port: 110
OUTGOING
security type: none
Port: 25
Require sign in: tick box
User name: Your email address
CatWeasel
Message 5 of 8
It looks like the problem was caused by outlook using a POP connection, I tested setting outlook to us an IMAP connection instead and that sorted the problem for me. I am not sure why this wasn't a problem on my old iPhone or for my g-mail (also retrieved via outlook using POP) but it seems it was an issue for BT Yahoo mail on my android. Thanks to Keith for pointing me in the right direction.
John55810uk
Message 6 of 8
Having searched the Google Play store I cannot find a "BT Yahoo" app, there is a however a Yahoo Mail app, but there are reports of issues with it since a recent update.
CatWeasel
Message 7 of 8
Hi John,
I wanted to have all my e-mail addresses in one app (rather than having multiple apps), the one I settled on after trying a couple of different apps, and would recommend if you are also an android user is Aqua Mail. My problem was for some reason when outlook retrieved the BT yahoo e-mails, it removed them from the yahoo mail server as well, so when my android synced later on there was nothing to retrieve anymore.
In my case I resolved the issue by setting the BT yahoo mail account on the android to use IMAP, and also setting outlook to use an IMAP connection (rather than POP3). If you let outlook automatically setup the connection for you it defaults to using POP3.
skldenton
Newbie
Message 8 of 8
I was desperate to get my mail working on the android, IMAP did not work, your solution using POP instead worked straight away.  Thank you
