Message 21 of 38
Re: Cannot send e-mails from 3g smart phone using my @btinternet.com address
@imjolly wrote:
obviously there is more than 1 setting that works
my htc is  mail.btinternet,com
security none
port 587
btinternet sign in
Its the SMPT server thats the problem, mail can be received fine, its just not authenticating correctly.
steve508
Message 22 of 38
tried to sign-in and use user name and password that i use to log into pc but keep getting setup could not finish
cannot safely connect to server
certificate hostname not useable for server: mail.btinternet.com
do i need to select some other username/password
obviously doing something stupid here?
can you help further?
Message 23 of 38
security none
port 587
btinternet sign in
that is my settings for sending mail and it works
Message 24 of 38
I am not sure, as I use IMAP, but I looked at the port numbers set up on my email program (Thunderbird) if it used POP3.
Is there any reason why you cannot use IMAP, as I know the settings for that, as its on my phone. Perhaps imjolly is using POP3?
Try his SMTP settings.
Message 25 of 38
 I am using pop3
Message 26 of 38
Then you had better carry on with this thread to save confusion with my IMAP settings Smiley Wink
Message 27 of 38
cheers keith
my outgoing is
mail.btinternet.com
security none
port 587
sign required
username   xxxxxx@btinternet,com
password  as per bt mail sign in
steve508
Message 28 of 38
success
i followed this and i can now send and receive and everything
i will now try to set up my contacts and thing- but thank you so very much
Message 29 of 38
The "team" got there in the end Smiley Wink
steve508
Message 30 of 38
keith
many thanks
you got me on the right track
and now im off and running
simply had to set up user name and password in line with my pc bt yahoo account
could not have discovered without your help
thanks again
suprised the shop assistants ("experts") could not help me fathom this in the end simple setting out
