Message 1 of 3
If I have accidentally loaded Chrome, how would I go about undoing this, it appears to be blocking Gmail which is blocking certain emails from coming through?
2 REPLIES 2
Message 2 of 3
Re: Chrome
It won't be Chrome that is blocking gmail. Gmail will have been blocked in your blocked senders list. You can check by logging onto your email account and clicking on your username at the top right then go to "Mail" then 2Blocked Senders". Scroll down until you fine the gmail domain. Tick the box beside it and click "Delete".
If however you want to remove Chrome, assuming you are using a Windows computer you will need to go to Settings then "Apps"  and scroll down till you find Chrome then click on it then click "uninstall.
Message 3 of 3
Re: Chrome
Sear Distinguished Sage, thank you so much for a super clear answer much obliged my dear x
