Jimny21
Newbie
Message 1 of 3
Connection OK but unable to open IE nor send/receive e-mails
New BT customer and set up my wireless connection Saturday. Having to post this from my works e-mail because unable to open IE nor send/receive e-mails using Outlook. Microsoft diagnostic suggested that access being blocked by a Firewall. Don't want to disable windows Firewall and couldn't access 'Avast!' to disable its Firewall. Anyone experienced this and can anyone help me get proper access? Does anyone have a BT Tech Support phone number I can use?
Ta.
2 REPLIES 2
Message 2 of 3
Re: Connection OK but unable to open IE nor send/receive e-mails
welcome to the forum
did you try connecting with ethernet cable to make sure you can get internet access that way?
Jimny21
Newbie
Message 3 of 3
Yes I did but still had the same problem.
