mikedorset
Message 3 of 7
Contacts not auto-completing in "To" box
Just been forced to "migrate" to the BT Mail app on my Lenovo tablet (Android 7.0). When I start typing the addressee's name or email into the "To" box the app does either auto-complete it offer options.
BT tech support could only suggest re-installing the app, which I've tried to no avail. Can anyone tell me why this basic capability isn't working, and how to put it right please?
6 REPLIES 6
mikedorset
Message 1 of 7
Words breaking into two
Have just "migrated" to the BT email app on my Lenovo tablet. Now many of my incoming emails are arriving with the text broken at the end of every line - so one line end, for example, "happ" and the next line starts "y".
Phoned BT tech support but they say they are not aware of the problem. Can anybody help?
mikedorset
Message 2 of 7
Doesn't work with "Share" in other apps
BT email app doesn't appear to work with the Share icon in other apps like BBC news. When I click on Share then BT Mail then mail opens but without the link auto-pasted into it. Used to work perfectly with BT Yahoo Mail.
BT tech support claim to be unaware of the problem, but I can't believe this is not affecting thousands of other users. (I'm using a Lenovo tablet and Android 7.0)
Can anybody help?
gg30340
Message 4 of 7
Re: Contacts not auto-completing in "To" box
You have not been "forced" to use the BTMail app. You have chosen to download and install it. You can use any mail app you choose and I would suggest that you use anything but the BTMail app at least until it has been in operation for a while and all the snags are ironed out.
I use Aquamail on Android, There is a free version or a paid for version. For the few pounds that it costs  I would recommend using the paid version but you can obviously try it out on the free version first.
mikedorset
Message 5 of 7
Thanks for that. The "Migration" email I got from BT said my email would no longer work on the BT Yahoo app and that I'd "have" to download the BT Mail app to access BT emails on my tablet - so that's what I did.... From other post I've read it looks like there are all sorts of problems with the BT app....
gg30340
Message 6 of 7
I have moved your posts onto the same thread because they are all related to the BTMail app that you have installed.
I have already suggested not using the BTMail app in one of your posts and I would suggest the same for your other posts.
mikedorset
Message 7 of 7
Thank you. I am now using Outlook, as I do for other emails, and everything's working fine.
As, long ago, a quite senior employee of BT, I would have expected a lot better from them.....
