I want to list my contacts by surname rather than first names. There used to be a choice available. At the moment with new improved BT Mail it seems like you can only list by first names. Any advice about how I can return to listing by surnames - and a list which doesn't fold away contacts when there are more than 4 names under any particular letter of the alphabet. Any help / advice much appreciated.
Solved! Go to Solution.
Log onto your email and click on the contacts button. When the page loads go to the colum where the alphabet is listed. You will see a "down arrow" Click on that and select "last name".
Snap
But you said you were on the new BTMail not BTYahoo.
That's what I read as well.
