Message 1 of 6
Contacts
Is it possible to easily import a complete address book from Thunderbird?
5 REPLIES 5
Message 2 of 6
Re: Contacts
from thunderbird to where?
Message 3 of 6
Re: Contacts
Hi,
My Thunderbird is giving problems and I would like to copy the addresses to my BT mail
Message 4 of 6
Re: Contacts
You can "export" your contacts in T'bird by clicking on "Address Book"  then "Tool"  then "Export" to a file then open your BT Mail and go to "Contacts" then "More" and select "Import" and follow the prompts.
Message 5 of 6
Re: Contacts
Thanks gg, Ill try that.
Message 6 of 6
Re: Contacts
Hi gg, Success, thanks
