licquorice
Message 11 of 16
Re: Download Box Missing
Just another thought, has your task bar been accidentally set to auto hide.
raymond1234
Message 12 of 16
Thanks everyone for your help, I will try and clarify a bit better my problem
I have tried two PC's and they both have the same problem with the email page and also on two BT email accounts I have.
Download Box - security scan  sits at the bottom of the list of folders /boxes which sit on the left of my email page i.e.. Inbox Sent Trash My folders etc.
Is there any way I can do a screen shot without giving out personal information?
Aljaha
Message 13 of 16
Sorry I cannot help but is this what you are missing.
Use snip & sketch to select part of screen to save.
raymond1234
Message 14 of 16
email pageemail page
Scan of email page showing  top of security scan box on lefthand side of screen.
raymond1234
Message 15 of 16
Hi Everyone
Thanks for all your help, has suddenly started working ok, god knows what i have pressed.
Ray
Carlusha
Recognised Expert
Message 16 of 16
@raymond1234wrote:
Hi Everyone
Ray
Could your wife have done another cleaning session during the last hour? Miracles can happen occasionally!
