Message 1 of 5
Drag and Drop
Hi, apologies if I am in the wrong group 😁
How do I drag and drop emails I have received on to another one to send when each time I go to drag and drop the email keeps disappearing?
4 REPLIES 4
Message 2 of 5
Re: Drag and Drop
Email folders aren't accessible when the compose window is open in webmail, you can't drag and drop.
Its possible with MS Outlook but not Thunderbird.
Message 3 of 5
Re: Drag and Drop
Thank you so much 👍
Message 4 of 5
Re: Drag and Drop
You can not drag and drop an email into another email however you can send it as an attachment.
Click in the box that you want to send as an attachment then go to "Forward" in the menu bar click on it and select "Attachment" . This will open a new email with your chosen email as an attachment. You can then compose/complete the email and send as normal.
It will depend on the receivers device if it has the appropriate files that will open the attachment.
Message 5 of 5
Re: Drag and Drop
Thank you. I did think that but the person concerned was adamant I could do this.
