Is there a known ongoing issue with email login?
For 2 days I can't login to BTMail on the BT site, can't login to MyBT and Outlook keeps asking for a password. Weirdly the email app on my phone currently has no issues.
Normally this situation only lasts 24 hours or so but this has been longer.
I have checked passwords etc with no issues found, just get a TS-0003 error, even when I try to change my password.
Any ideas or knowledge of an issue?
Solved! Go to Solution.
Appears to be a VPN issue as disconnecting the VPN allows all to work....
