Message 1 of 3
Error code 553
Having sent some emails this morning I now suddenly cannot due to every attempt being rejected as Error 553 even when I remove all URLs from my signature and there are no attachments or rude words.
What is going on and how can I fix it?Screenshot 2023-02-22 at 11-59-56 Drafts - nina.baker1@btinternet.com.png
2 REPLIES 2
Message 2 of 3
Error code 553
Why are all my attempts to send emails being rejected by this error code? This suddenly started happening about an hour ago after problem-free emailing immediately prior to this.
Even if I remove all the URLs which have been in my signature for a long time, the emails still won't send.
How can I resolve this?Screenshot 2023-02-22 at 11-59-56 Drafts - nina.baker1@btinternet.com.png
Message 3 of 3
Re: Error code 553
Please don't post the same message more than once.
You will see from the forum that this is a very common problem that resolves itself.
There are a couple of things you can try. If you are using a VPN, try sending without using it. Secondly, you could try getting a different IP address by disconnecting your hub from line for half an hour or so.
