catpeople
Message 1 of 3
Favourite name security question problem
So, we have an email which got suspended because of "suspicious activity" - the screen said recover the account by changing the password, which led to a security question of "favourite name"
This is a question we never gave an answer to, so it's impossible to answer. According to a thread on here from 2011 it's a runtime error that actually wants a password with some other random letters/digits, but have no idea what the random bits might be, or how else to get to reset the password.
Does anybody know what the way round that question is - even to get to a genuine security question?
2 REPLIES 2
Message 2 of 3
Re: Favourite name security question problem
You will need to go down the route of forgotten security question answer and a PIN will be sent to you in the post. Start with 0800 800150
catpeople
Message 3 of 3
Thanks - I actually called one of the other helpline numbers after posting this, and got put through to the right department and they sent a pin and changed the password, so it's all sorted now.
