polish
Message 1 of 3
Help please
Logged in okay yesterday evening to my email and also to shopping sites on the internet, howver unable to log into email today, when I have checked for problems in my area and put in the phone number and it says you have an open fault!
I have not contacted BT to say there is any fault and yet it gives the date of the 15th September since this fault!  then why would i have been able to use broadband yesterday with no problems, can anyone throw some light on what this means please?
many thanks
2 REPLIES 2
Message 2 of 3
Re: Help please
If it is only your email that you can not log onto I would not do anything other than wait. This sometimes happens and usually clears its self.
polish
Message 3 of 3
Re: Help please
Thanks for that, but why when i type in my phone number to check for any problems it says ongoing fault!?
many thanks
