Message 11 of 15
Re: How do I setup a DKIM record with BT
"The advice you’ll find here is not intended for BT’s consumer customers but for senders of bulk emails to BT customers"
I'm looking to setup a DKIM as a BT customer
Message 12 of 15
That's because BT customers are using the BT servers/domain and they do not need to make any changes to anything as it is all correctly set up for them.
Even although you are a BT customer your are using your own domain so it must comply with BT.
Message 13 of 15
Nice one
v=spf1 mx a ip4:213.120.69.0/24 a:btinternet.com include:<my domain name>.com ~all
Works a treat👍
Message 14 of 15
is it possible that the bt server range has increased as I just got a spf fail  return because :
    5.7.26 not pass with ip: [213.120.69.111].
Message 15 of 15
Hmm, that address is covered by the /24
