pwalker3
Message 1 of 9
Incoming mail goes straight to Trash
I've had a number of emails from known senders going straight to Trash unread, bypassing the Inbox. Can anyone help resolve this please>
8 REPLIES 8
pwalker3
Message 2 of 9
Re: Incoming mail goes straight to Trash
Am I the only person to have this happen?
DavidM
Moderator
Moderator
Message 3 of 9
Hi @pwalker3 and thanks for posting.
I'm sorry to hear your emails are going straight to your trash. Have you changed any setting recently? Is your auto forward set to on?
Cheers
David
pwalker3
Message 4 of 9
I have not changed any settings, it just suddenly started happening. I use Apple mail to access my BT account. Mails are going straight to the bin even when the sender is in my Apple Contacts.
DavidM
Moderator
Moderator
Message 5 of 9
Thanks for getting back @pwalker3. Are you able to check if you're having the same problem via webmail?
Cheers
David
pwalker3
Message 6 of 9
Yes I do have the same issue with webmail, although the sender was not in my webmail Contacts. I have now added them to see if I now receive them to my Inbox, and not straight into Trash.
DavidM
Moderator
Moderator
Message 7 of 9
Thanks for that @pwalker3. Let me know how that goes.
Cheers
David
pwalker3
Message 8 of 9
Is there a quick way to copy all my Apple contacts to my BT webmail?
gg30340
Message 9 of 9
On your Apple device, export the contacts to a file and then log onto your BTMail and click on "Contacts" then click on the "More" menu button and "Import" the contacts from your saved Apple file into the BTMail contacts.
