clayto
Message 1 of 3
Is this a SCAM and not genuine?
Is this genuine or a SCAM email
2 REPLIES 2
J5
Message 2 of 3
Re: Is this a SCAM and not genuine?
100% not a genuine email, check the sender email....
Learn more about protecting yourself from scams :
https://www.bt.com/help/security/scams
Handling scam emails
  • Don't click links, open attachments or reply
  • If its seemingly from BT, forward as attachment to phishing@bt.com, if not report@phishing.gov.uk
  • Then delete the email
  • Even real-looking emails may have been spoofed
Additional tips:
  • Never log in to an account via an email if you are unsure, instead go to the website to log in "manually" at bt.com. This avoids you being caught out by potentially clicking on links you do not know. This applies to all your accounts online, not just BT.
  • Check the sender email
  • Hover over the hyperlink (do not click) to check the original link url
gg30340
Message 3 of 3
As already stated, it is a scam.
BT do not use gmail addresses to send out emails.
If you suspect an email as being a scam it invariably is. If you have any doubt do not click on any links contained in the email. Log onto your MyBT account using your normal trusted route and you can view your bill there.
