Springfields
Message 1 of 11
Kindle Fire and emails
Hello,
I may be in the wrong place here, but can anyone tell us how to SEND emails on our new Kindle fire?  We can receive them fine. We have a desktop with XP and use Outlook Express; we are with BT Broadband.  We thought we'd done everything correctly, but obviously not.
Many thanks.
10 REPLIES 10
Message 2 of 11
Re: Kindle Fire and emails
If its the standard Kindle email you are using and are happy with POP3 set up try these settings. (Obviously user name and password are your own BTYahoo ones). You may have used this set up
http://help.yahoo.com/kb/index?page=content&id=SLN4717&locale=en_US&y=PROD_MAIL_ML
If so just check the settings are the same as below.
Incoming:
Username : xxxx@btinternet.com
Password: xxxxxxxx
POP3 Server: mail.btinternet.com
Security: None
Port:110
Delete from server: Up to you
Outgoing:
SMTP Server: mail.btinternet.com
Security type: None
Port: 25
Require Sign in (Tick box)
User Name: xxxxx@btinternet.com
Password:xxxxxxx
Springfields
Message 3 of 11
Thanks very much...I've just tried that and it doesn't seem to work...it just keeps coming up with Delete Account from Device....and there's a Remove Account Box, presumably for me to 'click' on?  Why would I want to remove it please?  And when I changed it to port 25 it just kept going back to 587 or whatever it was...I've even forgotten that now!  I think it's addling my brain...we've been struggling for over three weeks now....  Thanks for trying....I'll keep at it and see what happens next.
Regards
VC
Message 4 of 11
are you trying to send email from you btinternet account on the kindle - or is it another email account?
Message 5 of 11
Try deleting account and set it up again. Passwords and usernames can be case sensitive so make sure you are entering them correctly. port 587 can be used instead of port 25 if its not accepted.
Message 6 of 11
You could alsp download the Yahoo mail app if its available at the Amazon app store. It is easy to set up and works well.
Springfields
Message 7 of 11
Yes, we only have the one account and that's with BT but our emails are not Yahoo. We are not very techie! thanks
Message 8 of 11
If your email is not with btyahoo you will need to have it verified so that you can send emails from it through btyahoo.
Message 9 of 11
Message 10 of 11
if you only have a btinternet account then there is no need to verify.  only 3rd party email accounts being sent from your btinternet email account need verified
