Rosanna
Message 401 of 490
Re: Locked out of bt email - stuck in a loop
Yes, after 6 days mine also started working this morning. And as suspected, all inbound mail during that period was rejected. Am looking forward to receiving details of my compensation.
HeyHey
Message 402 of 490
Doesn't work for me.
HeyHey
Message 403 of 490
Class action? About time these high charging companies made retribution for their failures, and in this case blatant lies and deceit.
MikeL
Message 404 of 490
Hi,
Web Mail seems to be back!
Cheers!
Regards Mike
mj2
Message 405 of 490
I'm back in via Outlook but web mail doesn't load the inbox. Not that I'm too fussed about that.  BT - compensation time.....Cat Happy
gillprior
Message 406 of 490
good luck with conpensation I have been offered £15
jonh46
Message 407 of 490
Re: Email problem
hmm situation partially resolved.
found my various email addresses were working again apart from my wife's. which appears to have been disabled.
I still have a problem with accessing my main id email using btmail login in browser.
I keep agoing around in a loop signing into my.bt id instead of mail account and not able to get to email account for main ID.
So I can't check bt spam filter for that account, change password or manage sub accounts,etc.
I can access the main id mail box using an email client. eg windows live mail.
Still waiting on a call back on 30th. I was promised a call back about my wife's email within a couple of hours, a couple of days ago but nothing.
Moderator
Moderator
Message 408 of 490
Re: Lost access to primary email account following BTID/Mail merge
 Hi @ndpas01 I called earlier to check if you have had this issue with your email accounts fixed. Can you post back and let me know if you are still unable to access any of your email accounts.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
MikeL
Message 409 of 490
Re: Reset Email Password
Hi,
I have just received text message while out shopping saying I have changed my password. It says if I haven't then go and reset it. I haven't done it so who has? I have been used browser to use forgotten password to reset it.
Is this a hangover from the resecent mail fiasco?
Are mods able to indicate if this has been done by BT?
Cheers
Regards Mike
Moderator
Moderator
Message 410 of 490
Hi @MikeL,
Your email is one of the ones reported as fixed. It would have been an auto email. Check to see if it's working for you please.
DanielS
Community ModeratorDannyS
Kudos”Kudos”
