Message 31 of 139
Re: MODERATOR
Hello Liquorice
Thanks yes have tried that and it does work, however will i have to disable it every time I log in now until BT sort it?
WIll I have to enable it every time I go into another site?
My elderly mum in law will not know how to do this, hope BT are going to sort soon.
One other thing my hub 6 has gone off completely about 10mins ago as I was replying to you and now got it back on again. thanks Jules
Message 32 of 139
Re: Logging in to email problems
@licquorice wrote:
I have notified the mods about the McAfee problem
Another reason never to use any of the junk McAfee programs that are supplied by BT.
Message 33 of 139
Re: unable to log into email or bt.com via firefox
Some people have found that turning off McAfee web advisor resolves the problem so if you have it installed try doing that.
Message 34 of 139
Definitely!!
Recognised Expert
Message 35 of 139
Like you, my password is rejected in Firefox but the same password works in Chrome
Newbie
Message 36 of 139
Same here. Couldn't log in today to an account I've used for years ("Please check you entered your username and password correctly and try again. If you need help remembering your username or password you can use the links below. "). Changed the password twice but no joy. My sister could log in from another device. Initially my Android phone was okay but once the password was changed I could no longer log in.
However, using Microsoft Edge I can log in using the new details (I was on Mozilla Firefox).
Message 37 of 139
I presume you changed to the new password on your phone. It has been found that when changing passwords it can take a while for the new password to sync with the servers so it is recommended to wait at least an hour after changing the password before adding it to the phone.
It might be worth stopping your phone from checking for emails on that account, ie turn your phone off and after an hour or so allow it to check to see if it has synced. If it hasn't you may need to change the password again and this time wait an hour before adding it to your phone.
Newbie
Message 38 of 139
Cheers!
Message 39 of 139
Tried disabling Web advisor no change.
Expert
Message 40 of 139
Similar problems on fully updated Chrome. Please fix this asap.
