Spike_66
Message 1 of 5
No connection when selecting a message
I can connect to my email on my Windows 10  Laptop. I can see recent emails. However, when I select one i get the message "Sorry, it looks like you are not connected to the Internet..." which I obviously am.
I am not getting these issues in my phone.
Ideas?
4 REPLIES 4
DavidM
Moderator
Moderator
Message 2 of 5
Re: No connection when selecting a message
Hi @Spike_66 and thanks for posting.
Are you still having problems with your email? Are you seeing any other error messages?
Cheers
David
Spike_66
Message 3 of 5
No - fixed now. I restarted the laptop and it's now fine. Maybe it needed to reissue a new IP address?
emmaarmstrong99
Message 4 of 5
Hello,
It can be fixed by using a different browser or by doing a Windows "Network Reset". To do this click on the Start Menu and type "Network Reset". When the machine restarts the issue should be fixed.
gg30340
Message 5 of 5
@emmaarmstrong99 wrote:
Hello,
This post is almost a year old and has been marked as solved by a simple restart of the OP's device. Why resurrect it.
