Alanrf
Message 1 of 7
Odd MAILER-DAEMON messages
Getting strange messages from MAILER-DAEMON@btinternet.com
Not a new issue really, but just over the last couple of weeks I have been getting intermittent messages, both to a couple of my accounts, my primary account as well as one secondary account.
The strange thing is that the messages purport to come from [myemailname]@btopenworld.com and are being 'sent' to non-existent 'btinternet.com' and 'talk21.com' addresses.
Strange because both of these accounts have been around since the last century, literally, and have always used the 'btinternet.com' suffix.
I have never used the '@btopenworld' suffix at any time so presumably these are being generated by some unwanted and unwelcome third party.
I have changed passwords as a first step in trying to stop the problems.  Let's hope that works!
A couple of 'headers' contained within the bodies of the mail were as follows - not sure if it makes much sense regarding origin and so on.
X-Originating-IP: [65.20.0.12]
Authentication-Results: mta1058.bt.mail.ir2.yahoo.com  from=btopenworld.com; domainkeys=neutral (no sig);  from=btopenworld.com; dkim=neutral (no sig)
Received: from 127.0.0.1  (EHLO smtpin09.bt.ext.cpcloud.co.uk) (65.20.0.12)
  by mta1058.bt.mail.ir2.yahoo.com with SMTP; Thu, 04 Jul 2013 15:20:43 +0000
Received: from [117.196.197.163] (117.196.197.163) by smtpin09.bt.ext.cpcloud.co.uk (8.6.100.01)
        id 51C27D6F05E01368; Thu, 4 Jul 2013 15:20:42 +0000
Received: from [192.168.0.156] ([192.168.0.156]) by phoenixsrv6.miyabinosato.com with Microsoft SMTPSVC(6.0.3790.4675);
     Thu, 04 Jul 2013 11:20:39 -0500
Authentication-Results: mta1012.bt.mail.ir2.yahoo.com  from=; domainkeys=neutral (no sig);  from=btopenworld.com; dkim=neutral (no sig)
Received: from 127.0.0.1  (EHLO smtpout03.bt.ext.cpcloud.co.uk) (65.20.0.12)
  by mta1012.bt.mail.ir2.yahoo.com with SMTP; Thu, 04 Jul 2013 15:52:05 +0000
Received: from 178-137-227-36-feod.broadband.kyivstar.net (178.137.227.36) by smtpout03.bt.ext.cpcloud.co.uk (8.6.100.01)
        id 51D4CEAB0028E6C5; Thu, 4 Jul 2013 15:52:05 +0000
Received: from 192.168.0.223 [192.168.0.223]
    by mailguard.tomtill.com
    with XWall v3.37f ;
    Thu, 04 Jul 2013 11:52:10 -0500
_________________________
Alan
6 REPLIES 6
Distinguished Guru
Distinguished Guru
Message 2 of 7
Re: Odd MAILER-DAEMON messages
Someone somewhere has hijacked your email address to send spam. They send messages to large numbers of random addresses; some of these will be non-existent, meaning that the messages are 'returned' to you. It's unlikely that your email has been hacked, and there's not much you can do about it other than wait for the undelivered messages to tail off as the spammer moves on to someone else's address.
vofsanity2
Recognised Expert
Message 3 of 7
    with XWall v3.37f ;
Alan,
If you go into your Account Information and then Mail Options, Mail Accounts you will find that BT has created an extra address for you that is "Your Username"@btopenworld.com
I suggest you use the following link
 https://api.login.yahoo.com/login/history?
to check the login history of your account.
Interestingly the source of the spam emails being sent (probably) from your account is hosted by
Critical Path Inc
I think your Mailer-Daemon messages are worthy of more detailed investigation.
Alanrf
Message 4 of 7
I was aware that the 'btinternet'com' and 'btopenworld.com' suffixes are interchangeable but as I noted, I have never used the latter suffix on the two specific accounts.
Anyway, I did log in to the Yahoo page referred above with both versions and the 'activity' is identical; all times were within my 'normal' window, as it were, and in every case the IP address recorded was my own.  Noting obviously suspicious there, I think.
Haven't had any more bounces today (yet!) but whether or not that is a coincidence after changing passwords only time will tell,I suppose.
Alan
Distinguished Guru
Message 5 of 7
Hi.
Altering the password will have no bearing on the receipt of mailer-daemon or other non delivery messages. As has been mentioned, your email address has been spoofed as the from/reply-to address in a spam run, meaning that all bounces end up at your email address. As you've noticed, the btopenworld version was used by the spammers, and since it's effectively the same as the btinternet version, then you will receive them.
It doesn't actually matter whether you've used btopenworld or not, there's no activiation for it as it just exists.
When some spam is received, it is very likely that you can get get two versions, one sent to each address suffix - spammers neither worry or care.
Distinguished Guru
Message 6 of 7
    with XWall v3.37f ;
Alan,
Critical Path Inc
Critical Path are the new BT Mail providers - there is nothing at issue here with regard this.
The spam injection point for the 2nd report is (probably) an infected machine in the Ukraine, the first report is India.
Alanrf
Message 7 of 7
Thanks for the responses which are somewhat reassuring.   At least it seems likely that there are no 'infections' on my box hereHopefully my AV software is doing its job on a daily basis and during the weekly scan.
Interesting that you mention the password issue Andy.   That password change strategy seems to be the only solid piece of 'advice' on the BT site although they do seem rather vague altogether on the issue of spoofed addresses.
Alan
