Petes1
Message 1 of 3
Outlook settings for Samsung Galaxy 7
Somewhere along the line I have messed up my settings for Outlook on my Samsung Galaxy 7 and can't get it to work. My incoming settings are
IMAP server: mail.btinternet.com
Security type: SSL
Port: 993
Outgoing are
SMTP server: mail.btinternet.com
Security type: SSL
Port: 465
Require sign-in ticked
What's wrong?
2 REPLIES 2
Andy_N
Distinguished Guru
Message 2 of 3
Re: Outlook settings for Samsung Galaxy 7
Hi, welcome to the forums.
Did you actually change any settings recently, or is it that you can't get or send emails - which may have just started to happen?
If the latter, then the thing to do is nothing, no settings or password change. The issue can sort itself out after a few hours or a few days.
(I assume you're in the UK ... and not on holiday/work abroad)
Petes1
Message 3 of 3
Thanks Andy. It just started to happen and I did impatiently change some settings. However, I have now solved the problem by deleting and then re-installing my Outlook account.
