PeterJ59
Message 1 of 4
Passcode
Hi a couple of weeks ago I was locked out due to a security breach on my account. I reset my password but now every other day I get asked for a security code each time I try to access emails. This is becoming a real nuisance
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Passcode
@PeterJ59 thanks for posting and welcome to the community. It sounds like you've set up two-step authentication, this is an added security feature to help protect your account and would be recommended especially if there has been a previous security breach.
You can find out more about two-step authentication on this link and can disable that within your profile if you want to.
Neil
PeterJ59
Message 3 of 4
Re: Passcode
Brilliant thank you problem sorted
NeilO
Moderator
Moderator
Message 4 of 4
Re: Passcode
@PeterJ59 no problem, I'm glad I was able to help. 😁
Cheers
Neil
