Toogloomy
Newbie
Message 1 of 2
Password problems using Outlook 2013
Yesterday i changed my BT email password using webmail (as i have done many times before) and it is working fine. I can send and receive as per usual. However when i changed the password in Outlook 2013 it does not like it and keeps telling me there is a send/receive error. I even tried the new password in Thunderbird and i am getting the same send/receive error there too, so i guess the problem is with BT rather than with those email programs.
Is there anyone who can help with this?
I've read in many places that there maybe some issue with BT and Yahoo servers not being in sync. Is this true? If it is what is the way around it?
1 REPLY
Moderator
Moderator
Message 2 of 2
Re: Password problems using Outlook 2013
@Toogloomy Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
