CliveMB
Message 1 of 5
Problem downloading file attachments from emails
Currently using Windows Internet Explorer Vs8 provided by BT Yahoo but unable to download email file attachments no matter how small - even an 8K work doc. Box shows "Getting file details" with a flying document but nothing loads no matter how long I wait! Had this problem with Vs 7 so loaded Vs 8 - It was ok for an hour then problem resumed. Internet speed on computer is OK. Have Windows XP Home.
Can anyone advise me how to solve this problem.
CliveMB
4 REPLIES 4
Community Manager
Community Manager
Message 2 of 5
Re: Problem downloading file attachments from emails
Hi CliveMB,
Welcome to the forum.
Are you trying to download the attachment from your BT Yahoo email account?  Can you please try and download the same attachment via BT webmail instead of going through BT Yahoo IE8?
Type in the following URL http://www.bt.yahoo.com
You will need to enter your email address and password, this will give you access to your emails.  Try and download the attachment again?  I am just trying to rule out the cause of the problem being BT Yahoo IE8 as there have been a few issues with this.
Once you try this please drop me a post to let me know how you got on?
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
TracyR
Newbie
Message 3 of 5
I am also having this problem with email attachments.  I have tried signing in through the webmail service rather than yahoo IE8 but still can't open any attachments - is it my security settings?
Bygollyman
Newbie
Message 4 of 5
I am also having the same problem.  Any attachment will not download.  I am using Chrome, I have also tried webmail to the same effect.  I can forward the e-mail to another provider and receive the attachments.  This has happened before, the last time I ended up switching from IE7 over to Chrome to fix the issue.  This really needs to be fixed.
Message 5 of 5
Try using this log on.
https://signin1.bt.com/login/emailloginform
It could be that you are using an old log on page.
I presume you are using Windows XP as you are still using IE7, you should consider at least updating it to IE8 because of security issues with older browsers or to keep using Chrome which is more secure.
