Message 1 of 8
Problems connecting to email
Having problems connecting to BT email  The problem occured yesterday  Have tried changing password and using different search engines Normally use IE but have tried Chrome and Edge  It sometimes connects but continues to cause problems  Windows diagnostic check tells me that network set up is OK on computer and fault is with BT  (Error Code temporary DNS errer INET_E_RESOURCE_NOT_FOUND)  Any help will be greatly appreciated as I am a complete techno phobe
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Problems connecting to email
@Twitcher are you logging into webmail at www.bt.com/mail ?
Expert
Message 3 of 8
Re advice from Moderator to ensure login at www.bt.com/mail then the answer is that does not work
The result is:
This site can’t be reached
samlfed.bt.com took too long to respond.
Try:
ERR_CONNECTION_TIMED_OUT
Message 4 of 8
Yes , still having problems with connecting to email. Some times it works and other times it does not..
Message 5 of 8
Having mega problems connecting to BT email
Having problems connecting to my BT mail. Finding it very difficult to get through to check emails.  Normally I use IE but have tried other search engines including Chrome and Edge.  Keep getting message Error Code INET_E_RESOURCE_NOT_FOUND Windows diagnostics tells me that my computer is configured correctly Samfeld BT is not responding. Have spoken to BT who tell me that because I can still receive and send emails on my iphone and ipad the fault is with my desktop settings.  Can anybody please advise on how get onto to settings and fix problem.  I am a bit of a techno phobe.   Thanks in anticipation
Message 6 of 8
Cannot connect to BT mail on IE. Have to use google I would prefer to use IE is there a solution?
Having mega problems connecting to my BT email on IE.  Having entered email address and password it just will not connect with message samfeld BT is not responding. No problems getting through with Google though             could their be a problem with my IE settings.. Have cleared my cache on IE but this has made no difference  Any help would be appreciated
Message 7 of 8
Re: Cannot connect to BT mail on IE. Have to use google I would prefer to use IE is there a solutio
I have moved your post onto your previous thread so that anybody trying to help can see the history of your problem.
Message 8 of 8
IE is not supported on BT Yahoo mail anymore pretty much Microsoft themselves want to get rid of it -  use Edge, Firefox or Chrome ideally.
https://uk.help.yahoo.com/kb/bt/mail-for-desktop/SLN4556.html?impressions=true
