Do you mean
Expert
Problems with BTYahoo Mail
Hi,
I have used BTyahoo mail for 3 years and, apart from the odd glitch, have been happy with it.
However, over the last few weeks the performance has got progressively worse.
Sometimes it is slow to open and slow to move from sent > inbox >contacts etc.
Emails are slow to open.
Actions that used to only requires a single click nearly always require a double click and sometimes more than one.
For the record I have not changed my PC setup in any way, my mouse works perfectly in all other applications and my connection speed is the same as it has been for the last 2 years.  Time of day does not seem to make any difference.
Is anyone else having similar problems or know if there is a fix please ?
Best regards,
dfenceman
Re: Problems with BTYahoo Mail
I have been experiencing, and not for the 1st time, email problems.
I am using Outlook 2007 to receive my emails and iphone for when Im out and about.
Both have stopped working over the weekend and now Im confused and frustrated.
On Outlook,
It asks for the password and then tells me its not correct.
I have deleted it from Outlook and re entered the set up data from the help files on BT.com
I have logged in to MY BT and changed the password.
I have the same issues on the iphone and completed the same steps.
Please could someone enlighten me, I dont want to have to make a lengthy phone call to BT......
Thanks in advance for any help coming my way.
Distinguished Guru
@Jfletch  See reply in the thread that you started yourself.
You can click the white star next to this message if you think it was helpful.
Expert
dfenceman wrote:
Hi,
Hi,
Just wanted to bring the topic back on track after the digression of the last two posts please.
Best regards,
dfenceman
@dfenceman
my BTyahoo mail is just the same as always - so no problems
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
same here no problems never have had any to me it is as reliable as any other email services
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
john46
I wouldn't go that far
Guru
[ Edited ]
@dfenceman,
BTYahoo webmail all working fine for me and also quite fast on a 1meg connection to be honest.
Also fine using Mac (Safari), XP (IE 8) and Vista (IE 9).
Only thing I can think of is that your using the old version of webmail (classic) and I'm using the newer one (http://bt.overview.mail.yahoo.com/ )
Webmail Classic (older version) : http://uk.mg.bt.mail.yahoo.com/mc/launch?
The newer Webmail: http://uk.mg.bt.mail.yahoo.com/neo/launch?
cheers
jac_95 | BT.com Help Site | BT Service Status
Try a Search
Expert
Hi guys,
Many thanks for the replies.
@jac-95 - I'm using the latest version, not the old classic, via IE8 (64bit), on Windows 7.
Best regards,
dfenceman
Guru
[ Edited ]
ah okay, is it just lagging abit or being unresponsive?
Might be an idea to try and clear the IE History, IE Cache and Internet temporary files.
Hope you get it sorted soon,
cheers
Try a Search
