Message 1 of 10
Problems with POP email on iPad
My iPad is set up with POP BTinternet email. My wife’s IPad is also set up with POP BTinternet email. Both accounts are set up identically with identical settings. However, within the last couple of day, she can receive emails but cannot send any and there is no “Sent” box. On my iPad, I can send and the emails show up in a “Sent” box.  I have deleted her account and re-created it but the same problem persists.
Any suggestions as to how to resolve this problem? As we share the same account, I do not want to use IMAP because, if one of us deletes a message, it gets deleted for the other.
9 REPLIES 9
Message 2 of 10
Re: Problems with POP email on iPad
Hi @bratman91,
As you may be aware, we support IMAP rather than POP3. However, we do provide settings for POP3.
Check our BT Email server settings to make sure everything matches.
DanielS
Message 3 of 10
Which email app is she using on her IPad?
You stated that you have deleted "her account" but you also state " I do not want to use IMAP because, if one of us deletes a message, it gets deleted for the other".  which would imply that there is only one account and you are both using the same account and therefore she does not have her own account.
Could you clarify which it is because if it is the same account and it is working OK on your device then the problem would appear to be with either her email app or her device.
Have you tried downloading and installing a different email app to see if a) that works and b) if it clears the fault with the app she is using.
Message 4 of 10
To clarify, it is the same BT account but each iPad is set up with its own iPad email app account to use the BT email system (sorry, the terminology is confusing). There is no problem with my iPad or iPhone but there is a problem with her iPad. This has arisen only in the past one or two weeks - everything worked fine until then. She can send receive emails but not send them. The settings on her and my devices are identical.
Message 5 of 10
The problem with those settings is that they are generic and not always applicable to an iPad or iPhone. Most of my email accounts with other ISPs are indeed IMAP but I would like to retain the BT one as POP.
Message 6 of 10
Have you changed the email account password recently?
As regards the settings in the link that was posted by the moderator. Yes they are generic, that is because they are the correct settings regardless if it is an iPad or iPhone. If you are not using those settings, what settings are you using?
Message 7 of 10
@gg30340
The settings are:
Incoming Mail server
Host Name.    mail.btinternet.com
Outgoing Mail Server.
SMTP: mail.btinternet.com
Advanced
use SSL
Authentication: Password
Server Port 995
Message 8 of 10
What ports are you using. You have not shown the Outgoing Port.
Incoming should be Port 995
Outgoing should be Port 465
You need to check the Ports and settings as per the BT settings link I posted.
POP3 settings
Incoming Mail Server: mail.btinternet.com
Port: 995 (this should be automatically populated by selecting the SSL encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet.com or @btopenworld.com part
Password: your btinternet or btopenworld password
POP from folder: by default, POP will pull emails from your inbox
SMTP settings
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selecting SSL, so you'll need to check)
Authentication: PLAIN
Username: your email address including the @btinternet or @btopenworld.com part
Message 9 of 10
@gg30340
Unless it is well hidden, I can’t see any option to change the Outgoing Port.
Message 10 of 10
From the iPad home screen, Tap Settings. Tap Mail, Contacts, and Calendars. Tap the Email Account you wish to edit. Tap SMTP under Outgoing Server. Tap your Outgoing Server under Primary Server. Here you can edit the server port number by tapping the value next to Server Port.
See link
How to update SMTP (Outgoing Server) settings on iPhone / iPad - Knowledgebase - Jub Jub
