mikewood61
Message 11 of 17
Re: Problems sending emails via Outlook
This account corruption is the issue. Password is correct as I can access via webmail using bt.com not mail.yahoo.
It seems a relatively simple fix but.....
It’s need specialist help that despite dozens of calls nobody at BT can do. They keep saying they need to refer to their yahoo colleagues but it’s not happening.
gg30340
Message 12 of 17
As you have contacted the moderator as requested I would suggest that you no longer contact Customer Service and that you wait until a moderator contacts you once your request for help reaches the top of their work stack.
The moderators will take personal ownership of your problem and will be a "one point of contact" until the problem, what ever it is, is resolved.
mikewood61
Message 13 of 17
Phew!   Well thanks to the Moderators I had a call on Friday assuring me it can and it will be resolved.
This morning I can now access and retrieve my e.mails on Outlook.    So whats changed?  Well in my bt yahoo account (webmail) I now notice that the "original" yahoo email account that has numbers has appeared.    A quick password changed means that now passwords are re synchronising.
It is as was explained to me on Friday a bt passord sync issue that needs their intervention by a specialided team.
I hope this helps other
robmar0se
Message 14 of 17
Yes it does,  but there are several clients sufferring from the same issue - BT just says they are not interested.
Question how to get BT to address this issue more proactively.
mikewood61
Message 15 of 17
Hi
The issue has resurfaced now affecting my wifes e.mail account which is a sub account of my primary one.  Odd thing is that she can receive and send e.mails on her iphone but not in outlook on the imac.
Andy_N
Distinguished Guru
Message 16 of 17
@mikewood61wrote:
Hi
There have been quite a spate of similar issues recently that seems to affect Apple products. That can't be a coincidence. Of course, it's trying to work out the cause - which might be an internal Apple fault.
Ac3
Message 17 of 17
I have the same problem. The people at BT technical support are worse than useless. They claim to know nothing about this problem yet the following error message comes from BT:
