daz1971
Message 1 of 3
Re: Website on recurring BT Yahoo mail problems
Hi had the same thing for a good 4-5 days with 'Your e-mail server rejected your login. Verify your user name and password for this account in Account Settings.  The server responded: -ERR [SYS/TEMP] Server error - Please try again later.I did have eMail client and Mozilla Thunderbird although i now use mozilla thunderbird as was having problems with eMail client due to a persistant bug that i couldnt resolve.I have uninstalled email client but wasnt recieving any email and tried sending email with the above message that kept coming up.I tried doing the different suggestions as mentioned in the other threads.I decided to do a system restore to 7 days previous and when restarted was able to recieve and send emails again, I did have an Epson update 6-7 days ago which may be a coincidence i dont know which may or may not have resulted in the problem.So my advise is if there has been a recent update of any program etc i may worth looking into a system restore.😊
2 REPLIES 2
Andy_N
Distinguished Guru
Message 2 of 3
If I may ... the forum advice is actually do nothing. This has proved correct time after time. The reason is that if webmail works, then there is no password or settings problems (particularly if it has worked previously). This also affects other non PC clients on other devices, so a system restore is irrelevant in those cases.
A SR may be useful in some cases maybe if the other devices are working, and of course SR may not actually be activated.
Indeed certain updates can interfere rarely, in which case the settings of that update/programme need checking.
daz1971
Message 3 of 3
Hi Andy,Yes I totally agree just saying it maybe a option for some when most things don't work like myself for which it worked regarding updates etc😊
