Message 1 of 6
Re: filter unread emails
Hi, I have the same problem. Good thing you’re able to figure out the solution. I read your advice but am not very good with this. Are you able to explain this in a simpler way please. Many thanks 😊
5 REPLIES 5
Message 2 of 6
Log onto your email and if you look to the right hand side at the menu bar you will see "Change View".  Click on it and select " preview pane right".
You will now see a search box above the list of emails. Next to the search box there is an icon that looks like a funnel. Click on that and select "Unread". This will filter your emails to place your unread emails at the top of the list.
Unfortunately when you log off, the next time you log back on the filter reverts back to date order so you will need to reapply the filter again.
Message 3 of 6
Great! Thank you so much. This is really helpful. I’ll try to do this tonight 😊
Message 4 of 6
Hi @Raizel and welcome.
I hope @gg30340 advice sorts this for you. Can you please post back and let us know how you get on?
Cheers
David
Message 5 of 6
Hi, all sorted now. Thank you for the instructions you sent 😊
Message 6 of 6
That's great to hear @Raizel. Thanks for letting us know.
All the best
David
