Message 11 of 145
Re: Received email with no sender, no subject and message converted to plain text
Having the same issue
Message 12 of 145
Having the same issue with HTML included within text.
Message 13 of 145
Hi @MDTamar @RayDW @davidym
I have sent you a private message on here for some extra details.
Speak soon.
Leanne.
Message 14 of 145
Message 15 of 145
I am recieving similar  emails from trusted senders but when i click to open them
I get a blank page with No sender and No Subject
any idea what I need to do or is there a fix in place
kind regards Peter
Message 16 of 145
Hi @AMED1 @PeterWarrier
Thanks for coming to the community.
I have sent you both a private message to get some details.
Leanne.
Message 17 of 145
Hi Leanne  I have replied to your email message with some examples of the no sender no subject issues
hope they are of help to see what the issue is and get it resolved
kind regards Peter
Message 18 of 145
This "no sender, no subject" problem occurred for me earlier this morning. It seems to have sorted itself.
I use Mozilla Thunderbird as my email client BUT the problem only occurred with those emails sent to any of our btinternet.com addresses.
As said, it seems to have settled down now. I sent a test email from one of my non-bt email accounts to each of my bt email accounts around 1pm and all are OK as are those that have arrived since.
Message 19 of 145
Thanks Carlusha, that's helpful to know
Message 20 of 145
I have the same issue
