Karen1
Message 1 of 15
Recovering Mailboxes
If there a way to recover Mailboxes?  I would like to know how to do this incase I accidently delete one in the future.  I deleted one today but wasn't too important
14 REPLIES 14
licquorice
Message 2 of 15
Re: Recovering Mailboxes
Do you actually mean mailbox, i.e an email address, or do you mean a folder within your email page?
Karen1
Message 3 of 15
Apologies for not being clear.  I mean a folder within my email page.  I have checked in Archive and Trash and there are no emails so just want to make sure that any future deletions are kept safe and would rather check now how to do this.
licquorice
Message 4 of 15
Deleting the folder would just have moved the whole folder to  the Trash folder and you should be able to restore it.
Karen1
Message 5 of 15
Have just looked in there and its empty.  Is there a setting I can check?
licquorice
Message 6 of 15
No, there are no settings.
When you clicked on the 'X' to delete the folder, you should have had a warning saying 'Do you want to move <folder name> to Trash'  with Yes and No buttons.
Karen1
Message 7 of 15
I dont recall seeing that option (I deleted the mailbox on my phone).  I can set up a 'fake' mailbox and delete it and see if it asks that.  I have also checked the 'bin' and 'trash' and 'deleted'.
licquorice
Message 8 of 15
Ah, ok. I assumed you deleted it in webmail.
All bets are off if you deleted it in an app. You will need to check what the settings are for the app, it may have deleted the folder immediately. Which app are you using and Android or iPhone?
Karen1
Message 9 of 15
I'm using iphone, have a mac, but also looked in webmail and no sign of deleted emails there either.
licquorice
Message 10 of 15
Sorry, I'm Android so can't help with Apple stuff. How long ago did you delete the folder, the default time to empty trash is 30 days on webmail but your mail app may be set differently and permanently deleted it from the Trash folder after a much shorter time or even immediately. You need to check the mail app settings.
