Message 1 of 22
SMTP Problem
Hi,
I had BT infinity installed yesterday.  For normal web access it is working, for incoming email it is fine.  But outgoing email (to my own server) appears to have its attempt to open SMTP on port 25 diverted to 465.
It was working fine yesterday (when I was with demon) every attempt since to send email has resulted in this message from thunderbird:  Cannot establish SSL with SMPT server x.x.x.x:465 SSL_Conection_Error 1:error 140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
Thunderbird is setup to use port 25, the server is expecting 25 to be used  The x.x.x.x is the correct address of the server.
Richard
21 REPLIES 21
Distinguished Guru
Message 2 of 22
Re: SMTP Problem
It's trying to use SSL.
If not, I'll try again 🙂
Message 3 of 22
Re: SMTP Problem
But its not configured to, it wasn't yesterday and I haven't changed anything (other than Internet access to BT Infinity)
Guru
Message 4 of 22
Re: SMTP Problem
It's very common for ISPs to block outgoing port 25; even BE used to.
Will your server accept incoming SSL connections on port 587?
That seems the commonest setup where 25 won't work.
587 works for me from Thunderbird->goolge and a few others over Infinity; with Connection security set up as STARTTLS
I've also got a couple of connections on 465, configured in Thunderbird with connection security SSL/TLS
It sounds as if Infinity is switching the port, but not informing Thunderbird to switch connection security type.
Distinguished Guru
Message 5 of 22
Re: SMTP Problem
So you haven't configured the outgoing SMTP server on Thunderbird to use SSL?
http://www.names.co.uk/support/email/upgrading_to_ssl_for_smtp/1511-how_to_enable_ssl_for_smtp_in_mo...
Message 6 of 22
Re: SMTP Problem
I haven't configured anythng to use SSL, there is no need.
The server only accepts SMPT from an address that has already accessed it using POP/IMAP within the last 15 minutes.
I know what I am doing I want totatly unrestricted access from my internet connection.
Distinguished Guru
Message 7 of 22
Re: SMTP Problem
Try another mail client.
Better still, use telnet to access your mail server.
Works for me
C:\>telnet smtp.gmail.com 25
220 mx.google.com ESMTP e50sm17672300eev.13 - gsmtp
helo
250 mx.google.com at your service
quit
221 2.0.0 closing connection e50sm17672300eev.13 - gsmtp
Connection to host lost.
C:\>
Message 8 of 22
Re: SMTP Problem
Tried a direct telnet on port 25, it is definitely being mapped to port 465 by BT (and thus does not work)
Distinguished Guru
Message 9 of 22
Re: SMTP Problem
How come it works ok for me? What a mystery.
Distinguished Guru
Message 10 of 22
Re: SMTP Problem
Hi. Welcome to the forums.
As a matter of interest, what security product have you got ? Did you by any chance install anything when Inifinity was provided, e.g. BT desktop help ?
