Message 1 of 7
Samsung Galaxy S10+ default mail app will not work
Hi, I have recently swapped from my Samsung S8+ to an S10+ BUT the default mail app will not connect to server on my S10+ but is fine on my S8+ and the settings are the same, username@btinternet.com, IMAP, SSL etc
What am I missing or is this a glitch
It works fine if I browse to btyahoo and select mail but then that doesn't use the phone app
Confused !
6 REPLIES 6
Message 2 of 7
Re: Samsung Galaxy S10+ default mail app will not work
If you are using the BT server settings as per this link
https://bt.custhelp.com/app/answers/detail/a_id/44917/kw/bt%20mail/c/6591
You could try the Yahoo server settings as a work around. Be aware that using the Yahoo settings would appear not to register with BT that you are accessing the account and this could lead to the email account being deleted for non use.
If you do access the account by another device using the BT server settings or via webmail that will register it as being used and will negate what I have said above.
Yahoo server settings.
https://help.yahoo.com/kb/SLN4075.html
If you are already using the Yahoo settings you should try the BT ones.
Message 3 of 7
Thanks gg30340,
I used Smartswitch netween my phones and have checked the IMAP and SSL settings etc are correct
Are you saying that because I already have this setup on my S8 I cannot set it up on my S10
I did try removing the account from my S8 but, as yet, this does not appear to have helped
Tried using the BTYahoo settings instead but get advisory - The username or password is incorrect or POP3/IMAP access isn't turned on for this account ...
This is more than a tad annoying as I didn't have to do any of this on my S8 it just WORKED
Message 4 of 7
@NigeP wrote:
Thanks gg30340,
I used Smartswitch netween my phones and have checked the IMAP and SSL settings etc are correct I would delete the email account from the S10 and restart the phone. Once it has restarted try setting the account up manually using the BT settings in the link I posted.
Are you saying that because I already have this setup on my S8 I cannot set it up on my S10 No. You can set it up on as many devices as you want. What I was saying was if you use the Yahoo settings you need to make sure that you either log onto your email account using a browser or on another device that is using the BT server settings.
I did try removing the account from my S8 but, as yet, this does not appear to have helped. As I said, you do not need to remove it from the S8 but switch the S8 off when you are setting it up on the S10 so that the S8 is not trying to fetch your email at the same time as you are trying to install it on the S10
This is more than a tad annoying as I didn't have to do any of this on my S8 it just WORKED Yes it should just work and most times it does.
Message 5 of 7
Great. Many thanks. Why didn't I think of it .. duh ! Back of the class !!
Message 6 of 7
None of that worked for me on a Note S10+. The same details work on an iPhone however.
Message 7 of 7
None of what worked?
What email app are you using?
What settings are you using?
