lara19
Message 1 of 8
Setting Up Sub Accounts
Hello,
I have a primary account with BT (@btinternet.com) and I am trying to set up sub accounts for my family. When I go to manage my email addresses, there is no tab to add or create a new account, I only get the option to link an account. I have looked in the user guide and that advises that there should be an add/create tab available.
Can anyone help?
Thanks in advance.
7 REPLIES 7
Message 2 of 8
Re: Setting Up Sub Accounts
Welcome to this user forum.
Are you on the new BT mail, or the old BT Yahoo mail?
See http://forumhelp.dyndns.info/email/whichmail.html
lara19
Message 3 of 8
Hello.
Thanks for your help.
I was a BT Yahoo customer but am now just BT and using the BT Mail website.
I have already been on the forums but can't find the answer to my question - just wondered if someone on here would know before I go to BT.
Thanks.
Message 4 of 8
What e-mail service does it say you are on, when you use this link?
http://diagnostics.bt.com/login/?workflow=Email
If you are still on the old mail service, then this link will allow you to manage your sub accounts.
https://login.yahoo.com/config/login_verify2?.done=https%3A%2F%2Fbt.edit.client.yahoo.com%2Faccounts...
lara19
Message 5 of 8
Hi,
I am BT and not BT Yahoo - tried logging in on the Yahoo link you provided just incase and can't.
Moderator
Moderator
Message 6 of 8
Hi Lara19,
I'll be able to take a look at this for you. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
lara19
Message 7 of 8
I have emailed you - thanks.
Moderator
Moderator
Message 8 of 8
Thanks for taking the call this evening lara19. I'm glad to hear you got it all sorted yourself. If you have any other queries please post up and we'll be happy to help.
Cheers
David
