Message 11 of 16
Re: Spell Check
Hi - yes the link you sent me takes me to my emails.  The spell check doesn't work.
Message 12 of 16
Re: Spell Check
It is the  browser that you use to access your emails has the spell checker not the BTMail system.
If the spell checker is not working it is a browser problem not a BTMail problem.
What web browser are you using?
If it is Firefox check this link.
How do I use the Firefox spell checker? | Firefox Help (mozilla.org)
Message 13 of 16
Re: Spell Check
Are you sure its Firefox that is opening and not a different browser? Works fine for me.
Message 14 of 16
Re: Spell Check
I use firefox.
Message 15 of 16
Re: Spell Check
Thanks everyone.  I think i need to do a bit of research and try a few things.  Will get back to you tomorrow.  Cheers, Kim
Message 16 of 16
Re: Spell Check
Hi Everyone.    Yipee!   Thank you so much - its working.  I readded the Firefox dictionary from your link - and hey presto it all worked.  Fantastic!  Thanks again,  Kim
