am1985uk
Message 1 of 3
Thunderbird Problem
I am running Thunderbird on both a desktop and a laptop, and have done for several years. A few days ago I found a problem accessing the BT server from my laptop. A window opened with the error message "You are about to override how Thunderbird identifies this site." The location is shown as mail.btinternet.com:995
There is a button labelled "Get Certificate", but pressing this just gets the response "No information available." At the bottom of the window there is another button marked "Confirm Security Exception", but this is greyed out and unavailable.
I have checked through my account settings and made sure they are identical on both machines, but I am still in the situation where the desktop works fine, but the laptop doesn't.
Can anyone advise me what to do?
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Thunderbird Problem
It sounds like you are running an old version of Thunderbird, have you installed the latest version?
am1985uk
Message 3 of 3
Hi,
Thanks for coming back to me. Thunderbird is set to auto-update on both machines, but I notice that the desktop is on release 60.4.0 (the current version), while the laptop is on 65.0b4 (Beta version). Why they are different I don't know.
Update. This morning I tried to run Thunderbird on the laptop three or four times and kept getting the same error message. The fifth time I started it I got the error message again, but this time the option to get the security certificate produced a different response. I clicked on this and the error message went away. Since then I've restarted Thunderbird a few times and it appears to be working OK.
What has changed? No idea. Will the problem return? We shall see.
Regards,
Alan
