newbold3
Message 11 of 18
Re: Unable to insert link into email body text
Thanks, yes, 2 years and BT have still not sorted it! xxx
licquorice
Message 12 of 18
What are you talking about, if you read the OP's posts it was a user error problem that was resolved.
gg30340
Message 13 of 18
I wonder why the OP would have said it was user error and marked the thread as solved, could it be because it was!!
Perhaps you have not read the post or you have a different problem in which case you should start a new thread and state what your problem is.
newbold3
Message 14 of 18
Not user error, I was only migrated a few days ago but been looking for a fix for about 5 years because seen that my friends on BT also have this problem, can you help, also my contacts have not come over correctly.
gg30340
Message 15 of 18
If you have a problem, start a new thread instead of posting on a two year old thread that has nothing to do with the present migration and has clearly been resolved for the OP and has been marked as solved!
newbold3
Message 16 of 18
OK, thanks for your help and advice.
Karl x
Bp1Ransom
Message 17 of 18
Well obviously not been sorted out!
gg30340
Message 18 of 18
Did you read the whole thread which was about BTYahoo and NOT BTMal.
