Message 1 of 10
Unsafe emails
For the past 2 months the green padlock disappears from my email tab as soon as I open one. Firefox consistently tells me my emails could be accessed but does not explain what to do. BT Live Chat when asked finally after some time told me to change my pasword. Had to ask how and was told to followi a link. The link did not work. Using a BT search page  I managed to change my password and I  was told this was  successful  but not what to do next. I then tried to log into emails  using my new password but it was not recognised. I closed down, tried again but a message said I had logged in too many times, to try again in 15 minutes and if unsuccesful that a click on the messgae  would allow me to change my password. I did as asked, but still no success and message never reappeared. Consequently, I gave up, reverted back to old password and same padlock problems. Please can anyone explain in simple terms what I should do as BT is useless
9 REPLIES 9
Message 2 of 10
Re: Unsafe emails
It has absolutely nothing to do with passwords.
I suspect the mails you are opening contain content or links to non-secure sites.
Message 3 of 10
Re: Unsafe emails
Thank you but what do I do about the problem  and why did BT tell me differently?
Message 4 of 10
Re: Unsafe emails
There is no problem, just ignore it. The helpdesk know nothing.
Distinguished Guru
Message 5 of 10
Re: Unsafe emails
Hi.
Are you with BTYahoo or BTMail? Browser login will show a Yahoo image if BTYahoo.
The direct email change page is at :-
https://register.btinternet.com/cgi-bin/chpasswdsso
and should work straight away. I'm surprised it didn't work when you did a search for change password.
Frankly I would actually change password using the link above, just in case you were using a non BT page.
What version of Firefox are you using? I assume it's something like 57.0.4
You say it consistently tells you the emails could be accessed - is that actually all of the time that Firefox tells you this?
Message 6 of 10
Re: Unsafe emails
Thank you so much. I will do that. I'm with BTYahoo (have never been given any choice by BT) Not sure what version of Firefox I'm on to be honest - whenever I click on the grey/orange padlock Firefox  states my emails could be accessed
Message 7 of 10
Re: Unsafe emails
Still think it is just insecure content in the email.
Distinguished Guru
Message 8 of 10
Re: Unsafe emails
Only a subset of users were transferred to BTMail when the migration was stopped in Sep 2014.
Firefox version is got by clicking the "hamburger", 3 line icon at the top, then Help/About Firefox. If you've got the Menu bar, it's Help/About Firefox. If you've not got a menu bar, right click along the tab bar at the top and choose Menu Bar.
I believe licquorice is correct, though when I'm in webmail I see the green padlock symbol.
Do you have any firefox extensions?
Message 9 of 10
Re: Unsafe emails
I see the green until I open an email with images etc that are insecure.
Message 10 of 10
Re: Unsafe emails
Thank you both very much. Certainly changing my email password has made no difference to the padlock (so much for BT's Live Chat solutions!) Will now try to sort out Firefox or change my browser. Thank you again
MagM
